Internet connectivity options? | SatelliteGuys.US
ncted
6,119
4,335
Durham, NC
I am in the process of moving to OTA with Tivo to save money. I have a DECA box that is connected on an unused cable outlet in my basement that provides Internet connectivity to my HR24s. I would like to use that outlet for the first Tivo I am setting up to confirm reliability for the wife. My question is whether there is another way to connect the HR24s to the internet without using a DECA box. Both HR24s have ethernet connections available where they are located. Could I just plug them into my home network that way, or would that break the Whole Home functionality? Any advice is appreciated.
Thanks,
Ted
Looks like I only lose on-demand-type services if the DECA is not plugged into my home network. Will D* charge me a fee like E* if my receivers do not check in?
No fee whether you use it or not
You can take a Swm 2 way and put behind one of the HRs. One line going to HR and one to deca. Don't plug cat5 directly into back of rcvr. It will disable Whole home.
OK. Thanks. I will just leave the DECA disconnected and see if I miss it at all.
-Ted
Place to Get a New Hard Drive
