Invacom installation | SatelliteGuys.US
Rkey5
8
With a Fortec Lifetime Ultra I installed the new QPH-031 in a 90cm Dish but is not working. The best I get for Telstar 5 (IA 5 ) 97º, is Level 55%, No quality. Well, I am a newbie, and I have questions. For example, To get IA5 97º, Does anyone knows:
Setting the receiver.
- What's the LNB Type of the QPH-031?
- I know where to point the dish, but Where can I find the steps to set properly rest of the system ?
About the LNB:
How to know if it working properly?
Thanks for your help.
Rkey5
The LO frequency will be 10750...but we cant give you the angles until we get zip/postal code :)
(everyone' sangles are different)
also, make sure you are connected to a Linear port.. not a Circular port..
You wont be able to pick up IA5 with the Circular side.
Thank you, both of you. my location is 33014.
I played with the system a little bit and now is funny. I am pinting out to AMC 4 and I am receiving Level 87%, Quality 0%, but can you imagine that I am receiving also for Pas 1R Level 88%, Quality 0.
I don't understand, How come if AMC 4 is 101º and Pas 1R is 47º How come they are giving me the same reading?
Rkey5
Remember signal srength means NOTHING all you are interested in is QUALITY!
Code:
Hialeah, FL 33014
          Latitude 25° 53.778'N Longitude 80° 18.378'W
                         Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Telstar 12   15.0W 101.4 107.1 13.6 -61.9
                     Intelsat 901   18.0W 102.9 108.7 16.4 -61.3
                     Intelsat 603   20.0W 104.0 109.8 18.2 -60.8
                            NSS 7   22.0W 105.1 110.9 20.0 -60.3
                     Intelsat 905   24.5W 106.5 112.3 22.3 -59.6
                     Intelsat 907   27.5W 108.3 114.1 25.1 -58.6
                   Hispasat 1C/1D   30.0W 109.9 115.7 27.3 -57.8
                     Intelsat 801   31.5W 110.9 116.7 28.7 -57.2
                     Intelsat 903   34.5W 113.0 118.8 31.4 -55.9
              AMC 12 & Telstar 11   37.5W 115.2 121.0 34.1 -54.5
                          NSS 806   40.5W 117.7 123.4 36.8 -52.8
                        PAS 6B/3R   43.0W 119.8 125.6 38.9 -51.3
                           PAS 1R   45.0W 121.7 127.4 40.6 -50.0
                     Intelsat 705   50.0W 126.8 132.6 44.8 -46.1
                     Intelsat 707   53.0W 130.2 136.0 47.2 -43.4
                     Intelsat 805   55.5W 133.4 139.2 49.1 -40.8
                            PAS 9   58.0W 136.8 142.6 50.9 -38.0
                         Amazonas   61.0W 141.3 147.1 52.9 -34.3
           EchoStar 3 & Rainbow 1   61.5W 142.1 147.8 53.2 -33.6
                 Estrela do Sul 1   63.0W 144.5 150.3 54.1 -31.5
                     Brasilsat B2   65.0W 147.9 153.7 55.2 -28.5
                     Brasilsat B1   70.0W 157.4 163.2 57.6 -20.2
                 Nahuel 1 & AMC 6   72.0W 161.5 167.3 58.3 -16.6
                        DirecTV 5   72.5W 162.6 168.4 58.5 -15.6
                            SBS 6   74.0W 165.8 171.6 58.9 -12.7
                            AMC 5   79.0W 177.0 182.8 59.7  -2.7
                          Nimiq 2   82.0W 183.9 189.7 59.7   3.5
                            AMC 9   83.0W 186.1 191.9 59.6   5.5
                     Brasilsat B3   84.0W 188.4 194.2 59.4   7.6
                           AMC 16   85.0W 190.6 196.4 59.3   9.6
                            AMC 3   87.0W 195.0 200.8 58.8  13.5
              Intelsat Americas 8   89.0W 199.3 205.1 58.2  17.3
                 Galaxy 11/Nimiq1   91.0W 203.4 209.2 57.5  20.9
                     Brasilsat B4   92.0W 205.4 211.1 57.0  22.7
                        Telstar 6   93.0W 207.3 213.1 56.6  24.4
                        Galaxy 3C   95.0W 211.0 216.8 55.6  27.6
              Intelsat Americas 5   97.0W 214.5 220.3 54.5  30.6
                        Galaxy 4R   99.0W 217.8 223.6 53.3  33.4
                            AMC 4  101.0W 220.9 226.6 52.0  36.0
                            AMC 1  103.0W 223.8 229.5 50.6  38.5
                           AMC 15  105.0W 226.5 232.3 49.1  40.7
                          Anik F1  107.3W 229.4 235.2 47.4  43.1
         DirecTV 6 & EchoStar 6/8  110.0W 232.6 238.3 45.3  45.6
                          Anik F2  111.1W 233.8 239.5 44.4  46.5
                    Solidaridad 2  113.0W 235.8 241.6 42.8  48.1
                         SatMex 5  116.8W 239.4 245.2 39.6  50.8
          EchoStar 7 & DirecTV 7S  119.0W 241.4 247.2 37.7  52.2
  EchoStar 9/Intelsat Americas 13  121.0W 243.1 248.9 36.0  53.3
                       Galaxy 10R  123.0W 244.7 250.5 34.2  54.4
                        Galaxy 12  125.0W 246.2 252.0 32.4  55.4
             Galaxy 13/Horizons 1  127.0W 247.6 253.4 30.6  56.3
 Intelsat Americas 7 & EchoStar 5  129.0W 249.0 254.8 28.8  57.1
                           AMC 11  131.0W 250.3 256.1 27.0  57.9
                        Galaxy 1R  133.0W 251.6 257.4 25.2  58.6
                           AMC 10  135.0W 252.8 258.6 23.3  59.3
                            AMC 7  137.0W 254.0 259.8 21.5  59.8
                            AMC 8  139.0W 255.1 260.9 19.7  60.4
                     EchoStar 1/2  148.0W 259.8 265.6 11.4  62.3
        Satellite Finder is (c) Copyright 2004, P. Lutus
If you think you are on (or near) a satellite try a blind scan!
the higher the signal means you are near a satellite...dont know which one but I noticed when I move from one to another satellite, the signal goes from 70-74 when it passes a satellite :)
Hey! Thank you for your comments.
I follow what you said, both of you, and I did the power scan with Level around 88% and no quality, and power scan started to bring the transponders from AMC 4.
To both of you, THANKS!!!!!!.
To the rest who are just reading these posts, If you have any question don't think twice to ask in this forum.
Rkey5
Globecast LNBF
Any use for Directv receivers?
