Invacom OPH-031 & 90cm Fortec | SatelliteGuys.US
Richo
39
I just got an Invacom OPH-031 to put on my 90cm Fortec dish. When I opened the box and held the Invacom, I couldn't believe the weight. So, what I want to know is, is this LNB too heavy for the arm on the dish. I read a lot of good things about this LNB and hoping to see if it having higher gain improves any weaker transponders. I have a Tracker II now which I like but one dosen't know what one likes until one tries all the others. This FTA is a sickness..... is there a cure?
I have the same LNB on my 90cm Fortec. Been in use almost 2 years now with no ill effects on the support arm. Even with ice and snow adding weight in the winter. I wouldn't worry about it.
Thanks!!!! Tomorrow it goes on! Thanks again for such a quick reply.
Free dishes, free cables, free receivers -- (well, ok, they are usually old analog), Good information on SatelliteGuys,
[-- tongue in cheek -- spend what you need to for your system, then take your dog and go to a street corner wtih your sign saying you need food! (I met a guy in Seattle who made over $250 a day).-- tounge out of cheek.]
The hobby can be very expensive - but if it is very rewarding... I have had very poor results on FLeA bay, but good bargains and equipment from the 2 "S" Gold Sponsors.
ProgDVB Version 5.15
Equity Sells RTN
