Invacom settings | SatelliteGuys.US
Invacom settings
c-spand
1,408
845
USA
I put up an invacon universal lnb picked up better signal but the frequency is off by 5? Using a Edison osmio . should i change settings.
If the L.O. is off then doing a blind scan will show all the transponder frequencies off by 5. Not a real problem. But if you input the transponder frequency manually you may not get it because of the shift in L.O. Because it's a Universal LNB your Hi-Lo band switch is 5 off also so it may cause an issue getting signal at the edge of the range of each band.
Thank you magic. I replaced the lense on this too. It might have something to do with it. Signal is really good.
The lens is RF neutral. The Invacom's seem to have a tendency to drift off frequency with age. Have several QPH-031's that were 5MHz off several years ago and they are on a long list to check every few years to see how far off they will drift. :)
Tore one down many years ago and re-tuned the slug.
Reactions: c-spand
I just read an old article about that interesting. I guess i could take off the silicone and see what to adjust. I might buy a new one. Saw they still have the new ones with the circular and linear. It is really good lnb. I assume the news ones are same.
Just received a Channel Master 84E with dual LNB holder.
Question on the GEOSATpro 90cm Reflector
