Does Dish check location from IP address when receivers connect by Internet?
If they did it wouldn't matter much.
We sometimes connect with Hughesnet which the IP range is in Virgina. But most often we use the park Wi-Fi where we are staying. So our IP address changes as often a daily.
Why do you care? MOVER possibly? They don't care about that or the ip ,unless you are trying to put receivers in different houses then they would notice the ip address isn't the same.
Like Texas, New Mexico, Arizona, Colorado, Oregon, Washington, Montana, South Dakota, Nebraska, Kansas, Oklahoma>?If they did chk they would see you are in the same general area.
IP addresses change and really only give your general area.
IP addresses can be tracked right down to the computer, if someone wants to take the time and effort to do it. I'm sure if the IP associated with my internet service was given to Verizon they could track it down to my house. It doesn't make a difference if you have static or dynamic IP service either. Question would be would Dish really care enough or want to spend the bucks to do it....
Ross
Hard to say but each of my receivers has a different IP so I may find out if they care.
Given that all receivers must be located in one and only one location, it could certainly represent a red flag to see them with different IP addresses.If they did chk they would see you are in the same general area.
Same ISP but my receivers are connected on the WAN side of the router so each one gets its own IP from the ISP.Each of yours have a different external IP meaning you are using to different ISP's for service?
Location IDs have nothing to do with where the receiver is located. It is a code that changes every few seconds and they ask you for it when they audit to confirm that you have it within your home.There are location ID's in every set top box.
Limited time offer
