Ipad/iphone app sign-on issues | SatelliteGuys.US
No problem here. Reboot your device. If that fails you may need to download the app again.
Updated to new app version and can't get past the logo screen. App store comments are awash with others experiencing similar issues. Hope it's fixed soon.
There are several errors found in some lines of code for the APP software. It was found by the JB community. Ironically those of us that are JB and have the APP have access to the fix. So the tweaked version of the APP we are using that gets around JB detection is actually smoother, more efficient, and free of errors.
I am sure Direct is working on fixing theses errors and a new update should be available soon.
Direct can thank the hackers for finding these mistakes quickly and fixing it for them.
Sent from my Jailbroken iPad using SatelliteGuys
AM21 Not part of protection plan?
FOOTBALL!
