Chris07860 Active SatelliteGuys Member Original poster Dec 18, 2007 18 0 Jun 9, 2009 #1 I am thinking about buying that it would be my first Iphone is 8 gigs a fair amount yes I know it's no 16 or 32GB's also with the Iphone 3g can you Sync it with a bluetooth?
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,476 28,627 Newington, CT Jun 9, 2009 #2 With the new 3.0 software that comes out next week, I believe it does do file transfers via Bluetooth as well as Stero Bluetooth.
Chris07860 Active SatelliteGuys Member Original poster Dec 18, 2007 18 0 Jun 9, 2009 #3 oh ok so you can have the bluetooth headset with it?
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,476 28,627 Newington, CT Jun 9, 2009 #4 Yup you can.
Chris07860 Active SatelliteGuys Member Original poster Dec 18, 2007 18 0 Jun 9, 2009 #5 Sweet Thanks Scott :up
