I am going to be moving soon, and am going to seperate all of my home theatre components into an opposite corner or another room. I can handle all of my video connections to the TV with one HDMI cable, thanks to my sweet receiver.
I will need to get something to get the IR remote signals to the receiver, DVD player, Dish receiver, etc. There seem to be 2 major options and I wanted to know the difference.
Option A
I thought this was the only option, until I looked on Sat Guys. I am concerned there might be some delay or other downfalls. It would be less expensive and easier to install though.
Powermid Complete Set (Transmitter & Receiver)
Option B
This looks a lot fancier and high tech, but I am not sure what the practical advantage is.
Hot Link Pro
Option A
Option B
Hot Link Pro
