IR Remote Learning | SatelliteGuys.US
IR Remote Learning
sethwell
1,611
58
Booneville, AR
I thought the last software update addressed this. i've tried to program some of my tv remotes buttons to the 32.0 remote and it seemed like it took the commands but when i went to test it out the buttons were not working. the instructions on the 922 for remote learning are quite strange so i went to dish's website to get the info. they are the same for the 21 and i had that one programmed and working for a 722 i also have.
anyone else try this and did it work for you? thanks
Did mine last night and worked fine. I am asuming you are holding the tv button or three seconds then holding the record button for three seconds before to get into learning mode right?
yes, i did that. when i finish the learning process the SAT mode button blinks three times, not when i enter codes but when i finish the learnign process. is it suppose to do that or is that telling me that the learning process did not work? i know when you are programming a button and it does that then the button was not learned.
update: upon checking the settings in the remote manager i discovered that it did learn them. it says beside TV Code 1423(LG + Learned)
but it still doesn't work. frustrating.
Got my new 922...and got Harmony 880 to work too!
What happened to DISH Family?
