Is 61.5 an FSS ? | SatelliteGuys.US
Is 61.5 an FSS ?
So it's probably Diseqc. Pretty sure that's not Dish Pro Plus so it probably won't work with a 77,72,61.5 LNB like the OP asked. :)
A "multi-switch" is not a DiSEqC switch. They use 22khz tone for switching. The DP34 and DPP44 work with DiSEqC 1.0 and I have used both that way. If the OP does have a 4x4 multi-switch, then it can only receive two locations, not three. You need both H and V polarities output from two sats for the 4 inputs on the 4x4 multi-switch.
Reactions: TheKrell
:welcome to the forum aramd :) While everyone doesn't always agree on things, you can generally find the right information here. We are all glad to help.
Dish Network Markets list
netflix app question
