Is CW-200L LNB linear or Circular Pol | SatelliteGuys.US
miclow99
2
Sothern California
Gentlemen,
I am using a 33 inch Fortec dish with a Captive works LNB model CW-200L.
My target is Galaxy 25 ( IA 5).
My problem is that I am able to get the signal level to come up, but signal quality is zero.
Dish is plum and level.
Do I need a different type of LNB? or the problem is in my set up?
Is G25 a circular or linear polarity bird?
Any help is appreciated.
Thanks,
I believe your LNBF is a Linear standard. Look on the LNBF and see what the L.O. value is. If it is 10,750 then I have guessed correctly. G25KU is linear.
Bob
Motorized Primestar 84e
HD Receiver
