I agree with Brent. EMT is not rigid enough for anything larger than a 90cm dish. Use the galavanized heavy wall threaded pipe and you won't be sorry. Besides, you can tighten the dish mounting bolts nice and tight without the concern of crushing the pipe and possibly throwing the alignment off.
Ray
how do i tell the difference between these?
i just purchased a 10 foot 2 inch pipe i believe its EMT, it seems very sturdy, is the other kind sold in the electrical section? that is where i got this,
or are you talking about something like an iron sprinkler pipe which i would find in the plumbing section? (home depot)
Go to a plumbing wholesaler and ask for schedule 40 which is common and not too expensive. For my 12' BUD, I bought the heavier schedule 80 and intend to fill it with concrete for extra rigidness.
.....electrical EMT/conduit pipe......
I would not advise trying aluminum rigid conduit
......I would not advise trying aluminum rigid conduit....it's too easily bent being made of 5052 or 4043 soft alloy.......:
Mike11, stainless tubing is readily available also(I buy from Patton's Steel ). I thought you were trying to keep costs down.
Limited time offer
