Do you mean install physically? Of course it is possible! You just need another holder. But if you mean reception..... than it is also possible but performance of system will not be so perfect.sorry is it possible to install a circular ku lnb in a c band dish 10 ft ?
Thanks a lot for your informationIf you want to receive circular KU with a prime focus reflector, purchase a KU feedhorn/waveguide designed for illuminating a prime focus type reflector (with lower FD ratio) and a circular KU LNB (or circular and linear combo).
Circular KU LNBFs for the subscription services are designed for offset type reflectors (higher FD ratios). Mounting one of these LNBFs on a larger prime focus dish will result in seeing only a portion of the reflector surface.
Invacom is no longer making the c-120 flange mount circular/linear KU QPF-031 and they are harder to find. The c-120 feedhorns are usually found on EBay.
My bad, those areny circular
Limited time offer
