S sheyuid New Member Original poster Jun 17, 2006 2 0 Jun 17, 2006 #1 Can someone tell me is it possible to put 110, 119, 121 on one 33" dish? How to install ? TKS!!!
S Smith P. On Vacation Oct 4, 2003 8,907 2 Bay Area, CA Jun 17, 2006 #2 Yes. You can install 5 LNBFs at least for the dish; one problem is how you can manage to hold them ? I'm using a cluster from SD105 plus a couple LNBFs on zipties and wood inserts.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,335 14,679 Mankato, MN Jun 17, 2006 #3 What receiver do you have? Some receivers can't see 121 in the setup Otherwise a Superdish would work better
SimpleSimon SatelliteGuys Master Supporting Founder Feb 29, 2004 5,692 4 Florissant, CO Jun 18, 2006 #4 sheyuid said: Can someone tell me is it possible to put 110, 119, 121 on one 33" dish? How to install ? TKS!!! Click to expand... Yeah - as Iceberg says, what you want is a 121 SuperDish. Which just happens to be around 33" in size strangely enough.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,335 14,679 Mankato, MN Jun 18, 2006 #6 possibly. Just making sure his receiver can handle it
S sheyuid New Member Original poster Jun 17, 2006 2 0 Jun 19, 2006 #7 (I'm using coolsat 4000 pro clone, it can see 121). Someone tell me 121 and 119 is too close, so I can not attach 2 lnb. Is it true?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,335 14,679 Mankato, MN Jun 19, 2006 #8 Smith said: Canada ? Click to expand... nope. Stealer closed banned we do not tolerate hacking here
