Is Monster Strip blocking my DISHComm? | SatelliteGuys.US
IndianaMitch
12
... or do I have to "play" with my home network and name it HomePlug (I think that's it) because neither of my 722 units can see each other?
Unless there is a thunderstorm in your immediate vicinity, try plugging your 722 right into the wall and see if it can establish a link. Once you have your answer you can plug it back into the powerstrip.
I was looking for a HomePlug certified power strip online yesterday. Good luck with that. :)
Belkin used to have one but I don't see any mention of HomePlug compatibility on their web site any more and the part number I found online comes up empty.
SO..... how about a list of HomePlug compatible power strips? Is there something out there that won't break the bank?
TII HNP6 Surge Suppressor
Nice... found those on eB** for less than $40 including shipping
Yeah, I've actually seen them as low as $25, but I posted the Dell link since they are a reputable dealer. I had never even heard of the others that I found during my search.
Remove Hard Drive from 510...
Wgn Hd
