Is My 622 Dead | SatelliteGuys.US
Is My 622 Dead
bk63ross
SatelliteGuys Guru
148
San Francisco
Early symptoms were missing channels from the 110 Sat, then it starting dropping the signal saying acquiring sat, run check switch. So I tried a check switch then it would come back on for a few hours then do the same cycle again, this time I would unplug the power cords from the 622 and the power inserter trying to reset the switch matrix. Now all I am getting is an X where the ports and sats should be. Anyone have any ideas or fixes? I also replaced the DPP44SW today and am still getting the dreadded X!
622 or Switch
I will check them tonight. What concerns me is the way it's connected is everything feeds off of the bottom port # 1 on the 44 and it affects all sets in the house. If the 622 is working then all receivers are working. Is this right?
that doesn't sound right.
Each receiver should have it's own feed off the DPP44.
622 with a DVI cable
Echostar Earnings Call TODAY - Help Wanted
