Is my Voom STB activated? | SatelliteGuys.US
djm866
2
I just got my hands on a Voom DSR550 STB. I want to use it for OTA HDTV signals. How do I know if it has been activated?
That thread doesn't really have a section for "Is my STB activated?"
I have the same question - a lot of the things I'm told to check are using the remote, which I unfortunately don't have. Is there a way I can check if my VOOM DSR550 box is activated WITHOUT using the remote??
Thanks!
Yeah I've seen the remotes on ebay too - I was hoping to find out without buying one. I can power the unit on and it comes to a "split screen" - the top half of the screen says "VOOM" and has a little video window on the right side that says "WATCH" by it.
The bottom half of the screen has a bunch of menu options, like All Channels, All HD, Favorites, etc. But when I click on any of those using the buttons on the front of the box it just says "New program information is loading from the satellite. This process may take several minutes." I can't seem to get into the Help menu using the box's buttons.
I programmed one of my other remotes for the box and was able to do a little more, like punch in channel numbers, but still couldn't get into the Help menus. Another problem is the box doesn't have an 8VSB antenna module, so I can't punch in my local channel numbers anyway. I have one of those coming in the mail from ebay now.
The bottom line is: does the screen I get when I power on the box have anything to do with whether the box is activated or not? I've heard of some "activation required, please call VOOM" type screens, but I don't know when those show up.
Thanks! I'll probably pick up a remote one way or another anyway, but I was curious if I could tell before I get that, since I might return the box if it's not activated.
Sounds as if the box has been activated, but without the remote and having that all important green button, there is no way of knowing if it has the latest software. Early versions would not allow OTA channel scanning. If this is the case with your box, it will only work with the channel mapping sent down in the early days. And probably useless for you unless this box came from your local area. Best of luck to you.
Thanks!! I'm optimistic but I won't know for sure until I get the remote, which I have ordered now.
Voom STB Master Reset
dma set for different area
