They are still providing service but for how long is unknown. I started the thread below about this. Please join in there and add your current experience with them.I seen reports of orby tv not broadcasting any more is this true ?
Not really...Are you sure?
I just clicked on that link, it said this-Not really...
"...30-day risk-free trial offer expires 2/28/21. .."
This is a nice change from all of the threads we used to have about VOOM.I seen reports of orby tv not broadcasting any more is this true ?
I told you. Maybe next time listen. They were done. Orby and Voom go boom!,Can you confirm this?
Yep, they didI told you. Maybe next time listen. They were done. Orby and Voom go boom!,
Yes, the Orby dish uses a linear lnbf so it can be used for FTA. It is similar in size to the DirecTV Slimline dishes so it should pick up the channels one of those can get when they are modded for FTA use, like 97W, 95W, etc.Can I use the orby dish for FTA ?
Worked Sunday on Monday the 1st bye bye. Dvr local still work sat dead.
thank you I have an FTA receiver pre programmed for 97W. So I just point the dish and I am good?Yes, the Orby dish uses a linear lnbf so it can be used for FTA. It is similar in size to the DirecTV Slimline dishes so it should pick up the channels one of those can get when they are modded for FTA use, like 97W, 95W, etc.
P.S. Welcome to Satellite Guys!
Correct, if the receiver is preprogrammed. Just make sure it is set for an LO of 10750.thank you I have an FTA receiver pre programmed for 97W. So I just point the dish and I am good?
Depending on date of "programming" you may need to preform blind scan. Nearly every receiver sold with satellite list is dated.thank you I have an FTA receiver pre programmed for 97W. So I just point the dish and I am good?
Limited time offer
