is peace tv working on galaxy 18? | SatelliteGuys.US
peacetv
2
hi and thanks for any info, i just installed a dish on galaxy 18, some channels come in and rather strong (94), peace tv scans into the receiver but is just a black screen along with the other channels on that transponder. I think the signal is close to going out because it is 66. however i get a 63 signal on amc 4 before signal dissapears. I am wondering if the problem is with the satellite, or possibly the low signal. Also it says HD peace tv when i scan it, do i need an hd receiver to see it? any info much appreciated. also i read in another post that sometimes they scramble those channels?
I can't attempt an answer right now for the rest of your questions but, if the channel thats says "HD peace tv" is actually a high-definition signal then, yes, you do need an HD-capable receiver to view it.
working fine here
11967 V 7234
and the feed is in SD.....working on the Visionsat
HD means HDTV which is the uplinker
Peace TV is working here on my Visionsat IV200.
On a side note, when scanning AMC21 the other night, Peace TV and the other channels on that transponder on G18 scanned in as well as the PBS channels on AMC21. So bumping your dish a touch west may help improve your signal.
AMC 2-AMC 4
The Best Blind Scanning Receiver You've Ever Used?
