I cant get any answer out of Dish and I know it's been mentioned here a bit but I am wondering if this is going to happen with in the next month?
Channel launches are announced once contracts are signed. It is impossible to state when a channel will be launched while negotiations are ongoing.
You're not going to get an accurate answer out of Dish until they want to announce the channels. Oh, you'll get answers to your questions from CSRs, for example, they just won't be accurate (you'll be lucky if they're in an understandable form of English).
No one knows for sure if those two are EVER going to happen, let alone within the next month. However, the fact that they are apparently uplinked and taking up good space on 110 SEEMS to point to them being turned on, eventually, as opposed to being like InHD and MSG-HD and FSNY-HD which might NEVER show up, at least not in my lifetime.
=NLK=
So do you know for a fact that negotiations are ongoing with these new hd channels?![]()
Technically, they're not really uplinked, or at least it doesn't look that way. There are entries in the tables bearing the names SCIFI and USA in the HD channel range that show as MPEG4 HD. However, both channels are running an identical constant bitrate indicative of a slate. There's nothing to indicate that there's any actual content there.How long have they been uplinked?
They will be there soon, probably just after the next price increase.
Now let's turn this into another "what's your favorite show on SciFi?" thread!![]()
Now THAT would make more sense. We've all inferred that the two channels could be "close" because they're occupying valuable transponder space. I'm not tech-savvy but if you're correct then it may just be that the space they're "occupying" isn't scarce at all; i.e. Dish may not have anything to put in there anyway.
=NLK=
Seems like I've answered this question over and over with the same people
SciFi and USA HD that are not available are occupying space on 110. They are indeed taking up a valuable slot on 110 CONUS. It is correct that they are only running at 4 megabits each. Their left over bandwidth is being used by the other 4 PPV HD channels. Once content is fed over to the uplink side of the encoder it will adjust the bitrates based on their priorities and content. Just because they are on 110, I have a feeling they will be activated as soon as the ink is scribbled on the dotted line.
Your opinion... I don't wan't Blu-ray...so I order PPV's to prevent a 24 mile round trip...Would they just get rid of the HD PPV bandwidth hoggers and get the channels already.
Get a HD DVD or Blue Ray if you want to rent.
Limited time offer
