I'm 99% sure that the output is studio level, does the HDNet test pattern have a BTB section? If it does, should be able to tell that way. The VP30 may be able to tell me as well, I'll check tomorrow.ssj2 said:It's not that a device wouldn't be able to display the signal. In fact, digital RGB is likely more compatible than digital component.
Rather, the issue is whether black is represented by "0" or "16", and if white is represented by "235" or "255". Setting the display's input (if allowed) to match the signal's source levels of 16 - 235 (studio) or 0 - 255 (PC) is required for proper calibration of black and white.
Limited time offer
