OTHER - is there a manual for the microhd? | SatelliteGuys.US
OTHER is there a manual for the microhd?
if you do a factory resetd do you have to upgrade the firmware?
second, if I go to a new bird it says error: out of range. can't figure that one out either.
when I wanted to go to 97w and I have the dish motor set to o.o the dish didn't go anywhere. I did move it 7 degrees and was able to scan 97w but still trying to figure out the microhd commands. I do have a brand new amiko that is still boxed fup. maybe I should unpack it and use it? cvhasd
figured out stuff after titanium sent me the link for the manual. thanks. that is a titanium dish that I moved dfown from Nebraska. 1.4 k band I think. chas
