Thanx, this makes things quick and easier.Iceberg said:update your channel list?
I use Channelmaster
http://www.sharpc.com/CM/update.aspx
It allows you to rename channels, move them, delete them and keep a backup![]()
I use Channelmaster
Iceberg said:I just tried doing it directly from CM to the FOrtec and no go (I use a serial port)
but Fortec has their own channel editor built in if you use that (but CM works much better)![]()
Limited time offer
