the swm lnb on the slimline dish will power up to 8 tuners ...a single cable to the swm input on the hr21 will power each tuner in the unit... the swm cable has 8 channels on it...the cable can be split with a swm compatible splitter... each swm compatible recvr will pick a channel or in the dual tuner dvr's case (pick 2 channels) to use for its tuner...
you can do 4 dual tuner dvr's or 8 single tuner recvrs or any combination to equal your 8 channels...nice deal ... but you are limited to only 8 tuners on the swm lnb......
if you need more tuners, there are other ways to do it using other swm type of equipment ....this is for Directv only .....
