Is there anyway I can wire my Voom system in order to use my TV's picture-in-picture feature? I'm guessing the answer is no, but I figured I'd ask just in case. Thanks.
You can run the s-video or composite outputs from your Voom STB to the TV as well as component, and switch to that input source when using PIP.dnyce said:My RCA won't allow me to use PIP when using my Component or DVI inputs![]()
Anyone know a way around this??? It's sounds stupid to me....
FunkyBoss said:You can run the s-video or composite outputs from your Voom STB to the TV as well as component, and switch to that input source when using PIP.
My Hitachi can also have a PIP with two HD inputs. I am doing it with VOOM and D* HD.tdillon said:PIP is a function of your display device. You could upgrade the RCA by purchasing a Sony.![]()
Limited time offer
