WeeJavaDude said:There is a workaround there is you want to minimize it. I welcome you people experiencing this issue to participate in the poll.
The 811 is notorious for OTA issues. Hooking up an OTA antenna has exposed you to another set of 811 quirks. I've used my two 811's for more than a year now. Some problems have been addressed, and I've learned how to avoid most of the one's that haven't.MichaelG said:I didn't have this problem until I connected my SquareShooter to the OTA input. I finally got around to buying a couple of diplexers this weekend just so I didn't have to run a second cable to the 811. This was just yesterday and as soon as I hooked up the OTA, the guide gave me the No Info problem.
The 811 was never a problem befor this.
After about an hour of scanning for digital OTA channels, getting incomplete guide info and having general lockups, I unplugged the unit for a few minutes.
On power-up, the 811 reset itself and finally scanned correctly for the digital OTA. I got the correct guide info and I can channel surf using the up/down buttons.
I have not had any more problems since but plan on checking it again this evening.
mdonnelly said:The 811 is notorious for OTA issues. Hooking up an OTA antenna has exposed you to another set of 811 quirks. .
I hope your problems aren't too great, because local OTA in HD is much better than HD via satellite.
Limited time offer
