Is this right? | SatelliteGuys.US
Is this right?
rustolemite
67
Pineville, LA
I live in Louisiana and just recently added a new HD DVR and when setting up the receiver and this is the message it gave me when checking sats. Is this right ?
odd 99x 101check 103x 110 gray 119check
even 99x 101check 103x 110check 119check
Hope this makes sense ... just wanted to know if maybe my dish has moved ..
Rustolemite
There's a bunch of variables here...
What receiver did you have there before, was it an HD? Were all of your HD channels coming in? Is the new HD-DVR a HR-22? Do you have a Ka/Ku dish installed? Did you install the BBCs on the HD-DVR? If yes on all counts, I would normally say the dish is out of alignment, BUT the HR-22 is a huge pain in the ass right now. I have them all of the time failing the satellite checks when I know that the signal is there. Try resetting the receiver a couple of times, that may work. Also, has it downloaded the newest software, that helps sometimes too.
Directv PVR question
New to me...
