Issue with Create on AMC 21 | SatelliteGuys.US
rprenove
12
I have had a dish parked on AMC 21 for Create since it has been on AMC 21. Suddenly, I have totally lost Create and am getting no signal on 12179 V. However, I am getting a strong signal on 12140 V. I am also getting signals on 11876 H, 11891 V, 11894 H, 11900 V, and 11975 V. So I am really confused as to what has happened to my setup. Does this sound like the LNB has gone south?
Rick
Rick
I'm getting a very strong signal on 12180, and was earlier today also. Doesn't sound like the LNB or feedhorn if you're getting12140. Maybe a coax problem and it's falling off rapidly at the high end of the band?? Or maybe you just need to rescan the transponder?
you're on 127 because most of the transponders you posted dont exist on 125
other than the Montana gov't channel, all transponders on 125 are above 12100
My LNB type is 10750.
My only theory is the landscape guys must have hit it but I really thought I had it locked down. I will try and tweak it tomorrow. Thanks Ice for confirmation that it must be almost on 127 now.
B1 SAT STACK C-Band LNBF on 1.2M Dish
Quality Signal bar jumps from 0-62 %
