Scroll is running stating C-Band PBS on 103w will sunset March 4th, 2019.
Says Ku-band will still be available.
It's been nice knowing you.
I think you are correct. Seems I read/heard that somewhere/sometime.I Could be wrong but I thought PBS was starting to use a new interconnection system aka fiber for the file transmission to member stations and plans to kill all satellite over the next 5 years?
I heard that too. A lot can happen in 5 years though. Hopefully the more rural PBS affiliates will postpone the demise of the satellite service a little longer. Having East and West time-shifts available on the weekends is extremely handy. My wife and I enjoy "Masterpiece" and having two high quality HD streams will be missed.I Could be wrong but I thought PBS was starting to use a new interconnection system aka fiber for the file transmission to member stations and plans to kill all satellite over the next 5 years?
Well not sure why you deleted your thread and started a new one, but I will copy and paste my reply.
Will be sad to see it go, even though I never used it much. I have a dedicated 1.2M on 125W Ku.
Guess they didn't get enough of a response to their inquiry looking for C-band users... but maybe the decision was already made. I also have a dedicated Ku antenna for 125w but used the 103w feeds once in a while.
The local PBS station Prairie Public Television (OTA) was fairly reliable until about a year ago (spring 2018), I think they changed something at the broadcast site. Losing the feeds from 125 would be the end of PBS here.
Have to check for LPBS on 83 or 85w...
I watched PBS East on 125W Ku just 2 days ago - it was working fine, maybe a bit weaker than usual but the sky was quite cloudy. But I noticed that I could barely get Montana PBSHas anything changed on 125W AMC-21 in the past few months? I used to receive PBS there but after being away from home for a few months I now find that I receive zero there, including Montana PBS on transponder 10. The Ku LNB is fine, I receive Ku programming on every other bird I want to, and I can receive and peak the C-band signal at 125W G-14 just fine. I've tried tweaking the dish position (it's a 10-footer) and skew but still zero signal.
I've noticed that the OTA broadcast from the local PBS affiliate is even worse than it was 6 months ago, with a lot of pixellation and motion artifacts.
If I were a betting man I would put money on PBS, as we know it, being a memory 10 years (or less) from now, if it even exists at all. A huge portion of it's "programming" nowadays is infomercials and other crap and the good stuff that people hang around for, like Victoria, Doc Martin, Masterpiece, and Downton Abbey, for instance, are all available on Acorn and Britbox not too long after showing on PBS. Plus you don't have to put up with fund raiser interruptions watching them. I hope I'm wrong but I'm not optimistic.
Limited time offer
