Any iPad, iPhone, or iPod touch on firmware 3.1.2, 3.1.3, or 3.2 (not 3.2.1).
4.0.1Spirit. By far the easiest method. Have to admit, I only have iPod touch (2) so check if your particular model (3Gs) can be jailbroken by Spirit.
What s/w version is your phone running currently ?
Disregard the 2nd sentence. Spirit's website, Spirit, says it will jailbreak
I was thinking of tethering as in internet hotspot.You're misunderstanding "tethered" in this scenario. "Tethered" means the phone has to be connected to a PC anytime it reboots. Certain phone and iPod touch models and ones with certain s/w versions req'd this. It was less than ideal... If your phone crashed and rebooted while you're away from your PC, you're SOL.
I suspect you're thinking of "tether" in the sense of sharing bandwidth/data from your iPhone with other devices. Same word but different meaning in this case.
What I am saying is I have no idea which features on Cydia work with iOS4 and which do not. Anything that requires money will not be purchased by me until I know for sure. Considering all of the free things I have tried have yet to work, I cam even more skeptical. I cannot even get the friggen 5 row keyboard to work even though it is set to 5 row.Are you saying you don't want v4 of the iPhone's software ? In some situations, you can downgrade. I've kept both of our iPod touches at v3.1.2 for now... I realize with phones, in order to get newer "radio" software, it's beneficial to update.
Thanks. This will help. I noticed that there is a lot more red than green
I am actually restoring my phone. Not only are the few tweaks I wanted to do not available with iOS4, it has caused a few other issues with a couple of my apps not opening.
DodgerKing said:The one I had before. 4.0.1
Limited time offer
