Janeil Darkstar 12 foot. Yay or nay? | SatelliteGuys.US
coinmaster32
916
14
USA
Someone has a janeil dark star 12 foot dish for $50.
It is the kind that has the plastic frame and ribs.
Should I get it, or say the heck with it?
If it has the H-H motor rather than just an actuator arm that would be cool. I think the frame is composite rather than plastic, may not be bad either.
I don’t know where you live but here in Florida the sun turns anything plastic into dust! :eek:
Those plastic ribs may be brittle.
At $50 I'd pass.
Sent from my DROIDX using SatelliteGuys
Don't know where you live, so , I think I'll agree with the rest though, since I owned one of those things for awhile. The dish is kinda shoddy construction-wise, even though it was a great signal-sucker. The big ribs of the thing are just some kind of hard composite or plastic, and they are HOLLOW in the biggest part of the rib. Water tends to get inside, whether rain or condensation, and if you live in cold climates, it will freeze and crack the ribs. Mine cracked right where they attach in the center ring of the dish mount. then they get floppy, lol. If it has the H-H motor it might be worth the fifty, but I think I would probably pass on it. They aren't hard to assemble, but for one person , it turned out to be a nearly-all day job , haha.
I remember Turbosat talking about his plastic dish, in unkind terms. :(
I don't know why an H-H is assumed.
But it's got one, show some pictures so we can tell what kind it is.
You might want to spend the $50 to get a good H-H all by itself!
Just drop the dish off at the junk yard on the way home.
You can mate any sort of other dish to a good H-H and have a winner.
Of course, if no H-H included, run, do not walk... away. :)
AMC3 KU DVB-S2 Channels
Help pointing 101 LNB on Phase 3 Dish to 110 EchoStar 10/11
