Japanese FTA on 1 meter Dish
Here is info on Japanese TV that was posted in one of my threads. You might want to PM Dreamfox1 to check this information out more carefully.
If you try something like this I suggest the BSC-621 LNBF or the Geosatpro CK-1 LNBF. the Panorama LNBF was DOA for me twice.
Intelsat 9-----------------------------------------------------------------------------------
A.D venir digital
TV English
TV Latino
International
ENLACE
TBN-EJTV
Ocasional
525 English
525 Japanese
625 English
625 Japanese
Premium
DREAMFOX1
Dish is 39 inches in size.
SG 2100 DiSEqC H-H Motor
C-band lnb is Panorama ER-861
- Brand New; Special for Analogy and Digital C-Band Satellite Reception
Extended Frequency 3.4 GHz ~ 4.2 GHz (ZCF-D21)
Voltage-Controlled H/V Switching (13/18 V
Superior Low Phase Noise for Digital Application
Excellent D.R.O. Stability
Low Noise Temperature
High Gain Output
Light Weight Design
100% Waterproof
Super Compact Tooling
Scalar Ring Included
Best Solution for Multi-User System
Specifications
Input Frequency3.4 to 4.2 GHzL.O. Frequency5150 MHz (500 KHz @ 25C)L.O. Stability1.5 MHz (-40 to +70C)Output Frequency950 to 1750 MHzNoise figure13K typicalConversion gain55 dB typicalInput VSWR2.5:1 (maximum)Output VSWR2.0:1 (maximum)O0utput connector F female connectorOutput Impedance75 ohmsCross Polar Isolation20 dB (minimum)Image Rejection45 dB (minimum)Phase Noise-85 dBc @ 10 Khz (minimum)Supply Voltage11.5 to 14.0 V (vertical)16.0 to 19.0 V (horizontal)Operating Temperature-40 to +70CStorage Temperature-40 to +80CRelative Humidity0% to 95%Size168mm x 130mm x 190mmWeight680g
Can recieve
A.D venir digital
TV English
TV Latino
International
ENLACE
TBN-EJTV
Ocasional
525 English
525 Japanese
625 English
625 Japanese
Premium
G-28/C---------------------------------------------------------------------------------------
MUX 1211
MUX1212
BTHD
AMG TV
PMI-PIT PATH 2
AMC 6/C-------------------------------------------------------------------------------------
PA CABLE NETWORK
TV 2
TV 3
TV 4
G-11/C--------------------------------------------------------------------------------------
The World Network 2
World Network 2 AC3
TOC-DVIDS 1
TOC-DVIDS 2
SERVICE 2
Satmex-6/C--------------------------------------------------------------------------------
Service 1
UTEG
SIS-JAL-RADIO-TV
GPO IMGEN
TRECE TV
SNG
RGC TV
TELE MICHOACAN
TV-NUEVO LEON
G-23/C----------------------------------------------------------------------------------
HITN MAIN
HITN CH2
TVW 1
CST ENCRYP DLBY MPEG
CST ENCRYP BLBY DLBY
COX MPEG MPEG AUDIO
STO SD
G-16/C----------------------------------------------------------------------------------------
LESEA Network
