I have a couple of customers who have called saying that they heard that you can have joeys hooked up wirelessly, meaning no cable from node to joeys. is this really possible and if so how and what kind if equipment would I need?
I have had 2 WIFI joeys and 1 ethernet Joey running at the same time with no adverse effects
No super-router needed. Each stream is only about 6-7mbps. Any reasonable decent quality single band N network should be able to absorb that, most G nets would be OK.Cool. Do you have a super router.
What is the built in wireless in the new hopper for? Does it serve as an access point for wireless joeys or does it simply integrate an 'N' spec adapter into the equation, saving the usb port.
Limited time offer
