B blatimer1983 SatelliteGuys Pro Original poster Apr 6, 2010 288 185 Mississippi Oct 6, 2022 #1 Will Joey 4 work without Hopper Plus? Reactions: charlesrshell
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,668 29,759 Rohnert Park, CA Oct 6, 2022 #2 blatimer1983 said: Will Joey 4 work without Hopper Plus? Click to expand... Yes, but you can't get it installed without the plus. After installation you can remove the plus and the J4 will work but not without some issues. You would the same issues with the plus installed. Reactions: AkaDoubleG and charlesrshell
charlesrshell SatelliteGuys Crazy Lifetime Supporter Jan 14, 2006 11,247 5,979 O'Fallon, IL Oct 6, 2022 #3 I hope next Joey 4 software update helps with issues. Do you think the next update is coming soon Bobby?
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,668 29,759 Rohnert Park, CA Oct 6, 2022 #4 charlesrshell said: I hope next Joey 4 software update helps with issues. Do you think the next update is coming soon Bobby? Click to expand... I couldn't say... Reactions: charlesrshell
