YesAre these units 4k?
Are they android?
Do they have you tube?
Do they have caller id?
Caller ID is on the Hopper.Are these units 4k?
Are they android?
No caller ID on my J4s with my H3s.Thinking about it, I have caller ID, via the Hopper, on my 4K Joey and Joey 3. It is possible that the Joey 4 may have it as well. Maybe charlesrshell could give us advice, he has Joey 4s.
The biggest difference has all apps.what is the difference between the 4K joey & the joey 4?
The 4K joey is a standard DISH Joey that is capable of 4K programming (not very much of it at all) and the Joey4 is an Android Joey that does DISH programming as well as allowing apps from the Google Store.what is the difference between the 4K joey & the joey 4?
It‘s complicated. First the 4K sports on DISH (Channel 540) are HDR and live HDR is not available on the 4K Joey. There are some movies available in 4K and those work, sometimes. The built in app for Netflix will show 4K but not HDR. Prime will show both. As it is you might just as well get a Joey 3, it works though without 4K availability at all.when you say the 4k joey is capable of 4k programing (but not much of it)....are you saying that because there isn't much 4k programing on Dish or some other reason
So basically, should just get the joey4 and forget the 4k joey.It‘s complicated. First the 4K sports on DISH (Channel 540) are HDR and live HDR is not available on the 4K Joey. There are some movies available in 4K and those work, sometimes. The built in app for Netflix will show 4K but not HDR. Prime will show both. As it is you might just as well get a Joey 3, it works though without 4K availability at all.
You'll have to buy it from a retailer. Hopper +'s are on hold and Dish only installs Joey 4's with Hopper +So basically, should just get the joey4 and forget the 4k joey.
Does the Joey 4 have all of these restrictions?
It's the policy. Joey 4's have Android TV as the native OS. The Hopper+ Puts Android OS on the Hopper. Without it, the OS's are a mismatch.is that due to all of the issues with the product or some other reason?
Understand, but the hopper + is a flawed product. Why would people want to add problems to their system just to get 4k capability?It's the policy. Joey 4's have Android TV as the native OS. The Hopper+ Puts Android OS on the Hopper. Without it, the OS's are a mismatch.
The Joey 4's are also flawed. And now they don't work as well without the PlusUnderstand, but the hopper + is a flawed product. Why would people want to add problems to their system just to get 4k capability?
Any idea on the future of the Hopper+? I have the Hopper+ and Joey 4s so I am curious about future support.The Joey 4's are also flawed. And now they don't work as well without the Plus
Limited time offer
