Joey behaving badly | SatelliteGuys.US
Joey behaving badly
khrom
3
Suncoast
So for the first week everything went fine, no issues at all, the install seemed to go fine and tech did a decent job.
Then last friday evening, 6-29-12 the floodgates opened. We have a 2 hopper 4 joey setup, the hoppers seem to work fine, record ok, watch live tv ok, but the joey's..... oh the joey's have gone wild.
Lets start with one, it constantly goes down showing the 1303 error, sometimes it finds a hopper (not always the same one) and re-links up all by itself, other times I go in and manually reset the broadband/network, it may refresh the settings and connect other times nodda, if it connects and I then look at Whole Home page, it may see a single hopper, both, non at all, or just the other joey's. If the signal comes back and shows tv, it may last for 2 minutes, 45, an hour but it will eventually deceide it wants to send up another 1303 message, Looking for Hopper - "A3014........" or it shows the name assigned, or it has the 2nd hopper name, wait and it sometimes connects, or doesn't starting the loop all over again, reseting network.
I've tried the suggested unplug power, unplug cable, reset power/shutdown, startup, reconnect shutdown a few times, and well nothing.
A tech came out last tuesday and moved one of the hoppers to a different room, reconnected some ends on calbes but never once asked to look at one of the joey's. He was sceduled for a 12-3 arrival time, called and said he would be late, uhm a little closer to 430... ook, I shuldn't have left work at lunchtime then, but thats not the issue.
He left and not more than 10 minutes later the same joey went and threw up the 1303 page, called T/Support and was given a date on the 11th they would come back... Really yhe 11th, a full 8 days later when the tech just left 20 minutes ago?
Well today I get home and that same joey is now not able to even see a sat signal, local channels show not allowed to display this channel in your area, I was able to get CH 321 for about 20 seconds and then poof, lost sat. signal transponder # was changing then 2nd screen please select guide and or a previous channel.....
Needles to say.... it's getting very old dealing with this.....
So thats my Rant/Review and my 2 thumbs down so far on service (by 2nd tech and support - 1st tech did a good job)
Both hoppers are at the 213 and the one joey I can get to (mine) is at 265 all upadated on 7-1-12 after 1am.
I did a reset on the hopper I can see and that got the sat. signal back but still only seeing 1 hopper, no shared dvr content.
Seems like once again the general public is beta testers for this type of system.
Guess I'll keep hitting reset and refreshing the network for 5 more days till the tech gets here on the 11th.
do you have the hopper/joey connected to your network for ondemand? see if disconnecting all the ethernet cables and wireless adapters might stabilize your system.
__________________________
there's also been a few threads on 1303 linking errors on the forum like these. might have to dig around to see a version that matches up with your symptoms, but here's some examples when you run a search...
http://www.satelliteguys.us/hopper-zone/280523-joey-wont-link-4.html
http://www.satelliteguys.us/hopper-zone/282052-1303-errors-joeys-fixed-replacing-node.html
http://www.satelliteguys.us/hopper-zone/283294-1303-all-joeys.html
http://www.satelliteguys.us/hopper-zone/279345-joeys-wont-link.html
The one hopper did infact have wireless usb plugged in, this was also the hopper that I would see with the numerical name when it was looking for a hopper.
The ISP is Earthlink (cable) and is using Brighthouse connection. So far so good after disconnect and another red reboot button on this hopper.
Seems like the dhcp allocation between the wireless usb on the hopper and cable router was interfeering with me seeing this hopper as a number string and sometimes seeing it ok with assigned name - Living Room was casuing the joey to reset itself if this hopper would try and push new IP to it?
Hope this helps others, unplug the Wireless USB and see if it works. This setup was done on install and only started messing up after the 213/265 update on 7-1-12.
since the install is new, you might be able to get Dish to resolve this.
Is direct connecting with ethernet a possibility at any of your hopper/joey locations? The reason i mention it is that some have had good luck with using a HIC to avoid some of these networking issues.
delete multiple but not all recordings in a folder
additional location
