Joey connections | SatelliteGuys.US
Joey connections
TheKrell
A mighty and noble race originating on Altair IV.
39,060
47,071
Fairfax, VA
What do I get (or not, or mess up) if I have only moca connected, or only Ethernet connected, or both connected? What are the USB ports good for? Bluetooth? Wireless adapter?
I don't think you should blend MoCA and Ethernet mode at the same time. Should be one or the other. When I had four HWSs and one Joey I had all five units each connected by Ethernet cable to my router and they worked great in Ethernet mode. For my two Hopper 3s and two 4K Joeys I have everything in MoCA mode. I notice no difference in performance for either MoCA or Ethernet mode. The Hopper USB ports are used for EHDs and the OTA adapter is all I know of.
I don't think you should blend MoCA and Ethernet mode at the same time. Should be one or the other. When I had four HWSs and one Joey I had all five units each connected by Ethernet cable to my router and they worked great in Ethernet mode. For my two Hopper 3s and two 4K Joeys I have everything in MoCA mode. I notice no difference in performance for either MoCA or Ethernet mode. USB ports are used for EHDs and the OTA adapter is all I know of.
On a Joey? I think TheKrell had it right with the Bluetooth and WiFi adapters.
Reactions: charlesrshell
Missing DVR recordings
U517 New Problem
