Joey temps ? Joey locks up | SatelliteGuys.US
jim090
38
NA
:confused:What temps should a Joey be running ? swapped out Joey refurb. keeps locking up loosing local ota channels
I don't have any numbers for you. I did get a 2 hopper and 3 joey system at my parents house almost immediately after they were released. I noticed the Joeys were actually really hot to the touch. I changed them all from horizontal orientation to vertical orientation when I noticed it and they have been much cooler ever since.
At my house I have the newer Hopper with sling and 1 Joey. I stood the Joey up with the stand right away because I knew what it was like at my parents house. I have never noticed the newer Joey getting hot. I'm not sure if it's just because it is a newer unit or because it has been vertical the whole time I've had it. Sorry I can't give you any numbers but if you have your Joey laying flat I suggest you try to stand it up and see if that helps.
Yep my Joey can almost burn my finger if I touch certain spots on top while it's horizontal. If you can, run it vertical, it definitely helps with the heat.
Sent from my iPhone 4S using Forum Runner
Eastern Arc dish question
722K Problem
