One of my Hoppers is a hard wire connect to the home network. The attached Joey will not connect. I have tried all the available resets and reconnects with no luck. Any ideas?
If you have a password for the network did you give it to the Joey?
The network can.. mine does. If not I'd have the whole neighborhood cheating in on my line. When I setup the Joey it ask for authorization, but that's another story.A hardwired Hopper doesn't have a password.
jahost said:One of my Hoppers is a hard wire connect to the home network. The attached Joey will not connect. I have tried all the available resets and reconnects with no luck. Any ideas?
Your Joey won't connect to what exactly?
With the hopper hard wired, it does not send that connection to the Joey's. A hopper internet connector would connect all hoppers and Joey's to the network.
The only thing you lose by your Joey being hooked up to the network [its own IP] is DLNA support. All other content, BB@Home, DishOnDemand, and DVR content is accessed through the hopper itself.
isaacmorseMI said:Yes, it does.
Be a little more specific.
No a hopper will not connect your Joey to your network with the Joey receiving its own IP address on your network. I have not tried this myself, but it has been talked about in length that the Joey must have its own connection to the network for dlna.
And a Hopper Internet Connector is the only way to connect all receivers to the network without hard wiring Ethernet to each one, or using a wireless adaptor/bridge.
Yes for DLNA it must have it's own connection, unless that was resolved in S208/S260. But for all other uses a hardwired Hopper is best.
Limited time offer
