Setup is WA, wifi connected hws, hopper & 2 joeys. Has been an ongoing problem for some time. Both hoppers have been replaced previously, new lnb & node today. Also hopper & joey has been swapped around. Bridging enabled & disabled.
Still the same result with bad pixilation on joeys. Sd channel on 140 espn is the worst, does not do it on the hd version. It only affects sd, not hd. Also bringing up the guide on a sd channel is almost a sure way to pixelate the preview in the upper corner of guide.
The problem seems to be sd channels only & as odd as this sounds the action part of a sports show. Players on the court or field running etc. 2 joeys linked to different hoppers & different tvs with same exact problem.
Moca is good, all 4 lines are homeruns back to the node. No splitters, taps or other components. Longest run from lnb to farthest receiver is 75' or less.
On the hopper & the linked joey both tuned to the sd version of 140 espn there is a noticeable delay on the joey. At least by 2 secs, they were definitely not in sync. The hd version was almost identical on both.
Any thoughts? Known issue or something else?
