Join,merge two dishes (LNB) for better signal strength | SatelliteGuys.US
Dare
2
Hi!
I`m wonder how to join,merge two LNBs with same signal
for better signal strength, to One Sat-reciever.
Insted for using one bigger dish?
Thank You
Dare
You cannot combine/join/merge two lnbf's with the same signal or two dishes pointing at the same satellite to get a better signal strength. The only way you can get a better signal strength is to get a bigger dish and/or an lnbf with a better gain/accepts less noise.
ABC NEWS NOW: When Is It Returning?
Hallmark Channel Opinion...
