Just got my 61.5 dish ordered up. | SatelliteGuys.US
jmcgee_jr
219
Kirkland, WA
I moved recently and there was a dish already there so dish offered to put up a 61.5 orbital for me. Now I currently have DP34 does my install come with one for free? if so I can ebay mine off :). Also I added in the voom channells since my install is on the 21st and the new voom will be active around the 1st of january. I also did this in case they put up the DNS HD I figured Ill have 119 110 and 61 to work with for hoping I get em. If they go to the 148 Ill be mad cause there is no way in god's green earth im putting up another dish and for 2 I dont think I could get it here in VT with the moutain right there :).
The switch…no
They only use what parts you will need. Since you already have the DP34, they'll add the dish and hook that up into the 3rd port of the switch.
So what if I take out the DP34 an d just barrel my 2 connections together and leave my 3rd box offline for now. They would never know I had a DP34 right?
3922t
DP 942 L282 Bug Thread
