KC Local HD Audio/video problems | SatelliteGuys.US
aviatorbry
4
Ever since the HD local channels went live I have been having audio and video problems with all of them. Each HD local channel has a echo effect that happens every now and then. Then just recently the CBS channel has been having some pixelation at the top of the screen. The Fox channel audio is out of sync. I have called Direct and they have sent a tech out twice. The first time he replaced the H20 with another one. That did not solve the problem. The second time the tech came out and replaced the LNB and all of the connections. This still has not solved the problem. Every time I call Direct they keep telling me that it's something with my setup. The only thing left that we have not switched out is my 5x8 switch. I have tried a HDMI cable, RCA cables and Fiber. Each of these connections I'm having the same issues.
Anyone have any other suggestions?
As far as the audio, has the H20 update to the newest software version? What happens when you connect the H20 direct to the TV via coax or composite?
I get a echo effect either way. It dosen't happen all the time just every now and then. It sounds like the audio when a storm gets near by but not a frequent.
I have very much the same issue with my HD locals in KC, my signal strengths are all pretty low, I'm hoping when I finally call DTV they'll work to get my signal strengths improved rather than replacing hardware.
Aiming a 3LNB dish in metro atlanta, need help.
Length of cable wire before degrade of signal loss
