Well, rain finally returned to Georgia, and apparently water must have gotten into my LNB. Now, it took a while to diagnose that problem. But in the end it was ok; I had a spare. Unfortunately, the old lnb holder that came with my WSI 90 inch dish cracked to pieces when I tried to unscrew the rusty screws. The new LNB holder sits a little higher and angles back a bit further than the old one. I also decided it was time to put my dish on a pole mount in a bucket of concrete instead of my short rooftop mount nailed to a piece of plywood. Somewhere in the process, I broke the coaxial connector of the microHD STB. I just ordered one on ebay, and it's a good thing. I can't find another for sale anywhere else online
Again, thankfully I had the Amiko MiniHD as a backup, but I prefer the MicroHD for Ku-band scanning. This is a motorized setup. I panicked earlier when I thought the DG380 motor had gone out, but it was all because of the LNB, believe it or not.
Well, so here are a few questions.
1. For those of you that use a pole in concrete bucket method, how do you make things plumb and stabilize it from rocking around on the uneven ground (I put mine in a hole I dug out and surrounded it with rocks, but it's still a little shaky)?
2. For those who have changed out LNB holders, do you find you had to adjust the elevation of your dish? That was the only way I could get the channels to come back in, but the signal strength has decreased significantly. Before I play around with the dish more, I want to be sure I haven't done a no-no.
3. The old MicroHD still powers up, but the coaxial connector seems to have broken off (it swivels completely around). I attempted gluing it into place, but figured it had already damaged something inside the actual "LNB in" port in the circuit board. That seems to be the case. Although it powers up, it will no longer read any signals or move the dish. Is there a simple way to fix this? Does anyone want to try?
