Ku band lnb/ dish network lnbs ? | SatelliteGuys.US
Dishguy007007
Can you use Dish network LNBs to pick up Ku bands ?
Secondly whats the setting to pick up KU band on a super sat buddy ?
Not the Ku FTA band - requires an LNBF that's LINEAR polarity and receives 11700 to 12200 (optional - 10700 to 12200 -Universal LNBF)
Set L.O. to match the LNBF being used.
Set Transponder info to match a known working transponder on the satellite you're aiming for.
The above applies to C band as well as Ku.
No.
System, generic ku band, and h/v dual pol LNBF after you acquire one.
Edit: you are fast FAT...
Welcome to SatelliteGuys DishGuy!!
What satellite(s) are you after and what receiver are you using?
Perfect 10 vs Paraclipse
Altennative Magnetic Sensor Mod
