ku BAND LNB specially designed for a PRIME FOCUS PARACLIPSE | SatelliteGuys.US
kadnor
4
spun aluminium bud
Hi,
I shall require some useful advice about the selection of a ku BAND LNB specially designed for a PRIME FOCUS PARACLIPSE
8.3 ft antenna( with very small perforated alum rolled panels).
My existing C band LNB is ok, but I wish to move the system
eastwards to receive Panamsat 68.5*E and Thaicom 78.5* KU band CLEAR channels.I will remove the C band Lnb to enable more signal to penetrate on the reflector.
Secondly, my Paraclipse does not have any motor or actuator.
Do you think it will be difficuly to source supply for a motorised az sat-spotter. My receiver has interfaces for dis eqc 1.2 and 2.3 with possibility of return back.
Thank you in anticipation for the attention you will give to my query.
With much interest will wait for your e-response.
Best Wishes,
yours respectfully,
kadnor ( Mauritius, Indian Ocean)
Hello Kadnor I split your post from another thread and started a new thread for you here. You will get more help that way!
Nice to have you here :)
Any Disquec or USALS motors in works for dishes larger than 1.2m?
norsat 3220
