ku lnb | SatelliteGuys.US
ku lnb
What is "c band ku"?
Here is some specs on it:
Norsat 4106C Ku-Band DRO LNB
Input Frequency: 10.95-11.70 GHz. LO Stability +/-150 kHz. Noise Figure: 0.6 dB. Output Connector: Type F Female. L.O. Frequency: 10.00 Ghz. Conversion Gain: 60 dB
A lower cost digital DRO LNB, designed with a transmitter interference filter in it, with the commercial quality to be used in VSAT and selected digital applications. The 4000 is designed to provide higher performance for VSAT and select digital applications such as:
  • Higher data rate digital video, or commercial analog
  • Some SCPC digital or analog audio options
  • Any SCPC data rate above 1 Mbps
http://www.satcomresources.com/Norsat-4106C-Ku-Band-DRO-LNB
tanka, what kind of dish did you use it on? It is a ku lnb, If you have a corotor or a ku=only feedhorn it should be a good one, provided no defects.
New Retro TV Channels Coming in 2014
Witness show on Al Jazeera
