Hi,
Is it me does kusat 2600A not like DISqC swicth?
I end up loosing one connection or another.
But my pansat2700a with exact same setup and switch works without flaw.
LNB1 is AMC4
LNB2 is 76cm Dish with motor mostly at T6-T5-T8 sat's
LNB3 is Goltv at 110West
LNB4 is NASA TV at 119West
With the Kusat LNB1 and LNB2 both connected at same time i either find AMC4 or Echostar 110west but not at same time the same setup on pansat 2700a is okay.
Now i have the latest firmware i could find from http://www.digiwavetechnologies.com/index.php?module=documents&JAS_DocumentManager_op=viewDocument&JAS_Document_id=1&MMN_position=22:22
Any ideas?
And yes swicth work fine on pansat 2700a.
Thanks,
RtpiFan
LNB1 is AMC4
Any ideas?
Thanks,
RtpiFan
