L4.41 Software | SatelliteGuys.US
L4.41 Software
You mean this:
8/10/2007: Software Version L4.41 for ViP 622 DVR
Effective Friday, August 10th, Engineering plans to spool a PARTIAL PHASE of software version L4.41 for the ViP 622 DVR receiver. This is primarily a non-forced maintenance release available at ALL satellite locations.
At this time L4.05, L4.41 will be the valid software version for the ViP 622 DVR.
Because there's only a small number of 722s in the field and they're all beta testers at this point. When L440 and L441 were spooled the other day, it went to (280) 622 units and (100) 722s.
Now L4.41 overload by new beta:
PID=08BFh
DownloadID:'WITC'
Upgrading FW:
'BYC1': 'ABA1'- 'BYC0' 'L040'- 'L441'
New FW:'BYC1'
List of BootStraps and BuildConfigs:
'1[3-8]1[AB0-6]' 'RB[BDEGHKL][A-DJ]'
IRD Model: ViP622
List of Serial Numbers:
[329]
73406755 74411362 75814828 74597221 73406610 77387653 77412856 77419416 74411407 75094567
76478250 76961591 74413511 76774671 75937636 75094659 75768757 79832953 74407534 74411399
74413521 75814775 75814819 78470038 77371769 78287990 73406596 76634523 75761363 74411342
82364966 77371835 75139995 74407556 77384870 74411390 79850278 75867614 73406708 82342750
74990059 74990064 75085590 77385912 75896981 76477975 74411389 77561800 76781304 74819736
75522286 77415969 77563831 75582182 75690353 74945043 74819692 74819972 74990066 74766088
77371759 78278614 74411357 76477400 75501342 80057685 80057696 80057762 80057778 80095031
80095041 80095511 80095537 80095571 80095575 80095644 81068738 75094683 78470110 77388040
74819448 74819474 74819484 74819528 74819563 74819564 74819596 74819597 75867688 75891890
75230096 76460358 74411369 73406500 74676543 73406709 73406764 77393440 74597272 74413557
77385952 74597174 74819678 77265402 74596250 73406510 74597241 75094448 74413528 74413558
74597170 74601498 74413495 82364466 74596280 74597278 77564263 73406608 75504156 75766955
78472686 74413556 77265482 82359263 74407495 73406652 75829862 75230087 74411372 73174765
73406579 74413542 75041863 74601418 76775126 73406700 74411391 82197661 74411411 75867873
74407500 76472508 74407555 82929033 83166347 74596314 77371748 74411423 74597254 74596265
80118610 80151567 73406729 77371746 77385944 74411430 74596290 73406702 74596268 75867878
78469967 77332210 75793927 74601450 74413508 77387471 76956194 76956360 76956364 76961568
76472214 76655033 79958838 80151784 74411431 81066578 76182417 77332807 74596296 75094456
74407492 74407502 78469518 74819251 74819985 77393373 74407489 75664574 74411414 74596258
74413520 74407541 73406646 74411428 74413574 79850298 77560469 74411339 74413529 77470090
74407531 77371695 73406619 77561757 77575113 76181933 82676912 82676960 75094651 74411350
74413531 82341734 75771507 73406720 80057116 82676934 82342849 77385485 79850326 77336648
79850300 73406589 74819483 74819513 77328810 74407548 74413544 73406598 73406713 75582092
77370591 75814703 82363081 74411343 74411337 74601440 77425273 79895559 81477117 74407513
75867935 74413571 77370009 77385919 79850319 79850239 77279217 73406590 76477200 74411381
74766443 76478250 76460358 74676543 77371836 74601418 76775126 76477400 73174765 82676960
82676912 73406645 76781304 74411362 76961591 74819736 75522286 75085590 75582182 75690353
75501342 74945043 75504156 75766955 73406608 74597254 74819692 74819972 76956360 76961568
76956364 80151784 79958838 76472214 75664574 77575113 74990066 83226417 82943819 82667011
82929028 74766088 80057821 76774671 75768757 77563831 77415969 75310624 77388040 74413571
74597170 74601498 74413528 74413558 74597278 74411423 74819251 74819985 74407531 78470038
74819513 73406589 74819483 77328810 74407548 73406598 76477200 74411381 74766443 74990064
74990059 75041863 80057116 74990064 74990059 75041863 80057116 77624890 75318312
'1[3-8]1[AB0-6]' 'RJ[KLNP][A-DJ]'
IRD Model: ViP722
[95]
83879571 83956803 83879730 83956451 83956731 83879498 83956502 83956750 80057990 80057997
83956824 83956806 83956747 83956540 83956782 83956819 83880165 83880235 83878895 83880266
84093725 83956898 83879630 83879681 83880190 83879602 83956835 83956753 83879625 83956561
83879640 83956748 83956800 80057972 80057984 80057987 80057999 80058005 80058009 80058015
80058024 80058036 80058037 80058046 83956484 83956741 80058041 84059777 84125767 83956771
83956765 83956479 80058002 83956881 83956749 83879676 83956831 83956849 83879665 83956558
83879651 83956722 83879745 83880032 83879508 83956764 83956845 83956515 83879618 83956801
83956768 83956756 83879657 83956961 83879638 80058019 83956476 83956468 80057998 83956729
83880213 83956784 83880155 83878897 83956824 83956947 83879678 83956843 83879736 80058010
83956531 83879738 83956822 83880093 80057997
Hmm, does this mean that 441 is ready and they are moving on or does this mean they are back to the drawing board...
Hooked up my wireless bridge and worked great, so far, total time 5 min.
Still asked for a phone line on the Dish Home, 1,1,1 add programming.
I would call to change programming anyhow.
Received on both of mine - router showing two new IP addresses in use, Menu 6-1-9 confirms that they are on-line.
One step closer to being able to schedule recordings via HTTP!
Stability appears to be fine so far (after my post update manual reboot). No word on if the tuner enhancement (previously rolled out in L4.09 and later rolled back) are included in this revision. Can anyone confirm this? We've had issues with our local CBS affiliate, showing as 100% signal strength, but with frequent "freezes" and occasional "loss of signal".
I'm holding off on any external drive purchase (yes most of us who can read understand NOT UNTIL AUGUST 15th Scott ;) ) until you brave people (you know who you are) report back on if their 622 works with any drive over 750GB. Support for drives "up to" 750GB is the party line, but some believe that some (perhaps brand name) 1TB (1.5TB) drives may work. If I'm going to purchase an external drive, I'm going with the largest (yet reasonably sized) drive that I can afford.
Cheers!
One thing I've noticed, that I'm not sure is new or something I have overlooked.
Looking at my recording schedule, I recall seeing "1" and "2" icons, indicating which tuner said programming will record from. What I don't recall ever having seen is an icon representing an "antenna" for programming scheduled to record from an OTA source.
Is this new, or am I just not very observant? :)
my 622
is there a way to force the download on my current 622? Shutting off both tuners will that do the trick or just waiting for my serial # to get the hit on the overnight downloads??
Mike
I believe this is new. Will be a nice feature for my wife as I haven't received the update yet!
Mike
None that I know of Mike. The deployment appears to be tied to serial numbers, so if it isn't on the initial list, it wouldn't be receiving it.
Don't worry. Not receiving the update isn't always the worst thing. In the event there are bugs, you'll get to sit back and laugh at all of us expressing our frustration.
I'm no power user like Scott and Hall, but I haven't had any issues as yet. I am also watching my local CBS affiliate, and I have had no signal break ups (100% signal strength in the past resulted in frequent picture freeze and loss of signal messages on recorded content).
Cheers,
Spence
When Can I Order NHL Center Ice?
I can't get Dish to replace my 622
