L6.14 reboots 722 | SatelliteGuys.US
L6.14 reboots 722
Grumpy
23
Austin, TX
Ever since my 722 downloaded the new firmware, my DVR reboots when I try to manipulate any recording. I select skip/restore for example, it appears to hang for a couple minutes then reboots.
What's the deal? It was fine before 6.14
I'm getting the same thing on my 622. I tried pulling the power yesterday to force a hard reset but it's still doing it. Any attempt to use skip/restore or modify an existing timer in any way (including deleting a timer) will cause a crash and reboot.
I think I found a solution for this. I thought maybe something was corrupted in the timers, so I decided to try deleting them all and re-creating them. (I had about 40.)
Deleting them caused another crash and reboot, which I expected. The first time I tried to create a new timer (to start putting all my old ones back) it crashed again, so I guess it wasn't the timers themselves.
Then I figured it must be the program guide data that was corrupted. I remembered reading somewhere else that doing a check switch will usually cause the receiver to reload the guide data, so I did a check switch and it did sit there for almost 10 minutes fetching new guide data.
Then I proceeded to put back all my timers and not a single crash. Tried using skip/restore and no problems with that either. So I suspect that just forcing a reload of the program data by doing a check switch would have cured the problem without the hassle of having to re-add all my timers.
Default settings
I had a weird problem with OTA channels a couple of months ago and tried the usual fixes, I then did a reset to default from the menu and that fixed it, not a first option because of the hassel but not a hugh headache.
Buy My Own 722 Units?
Keep loosing channels on 118
